Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Amazon Fire HD 8 12th Gen Screen Replacement
Ce dont vous avez besoin
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: étape 1, image 1 de 3 Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: étape 1, image 2 de 3 Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: étape 1, image 3 de 3
      • Remove the device from any electrical source and make sure it is powered off.
      • Put picks around the corner and move them along the edge to pry the case off.
      • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
      Demander à FixBot
      Ajouter un commentaire
    2. Amazon Fire HD 8 12th Gen Screen Replacement: étape 2, image 1 de 2 Amazon Fire HD 8 12th Gen Screen Replacement: étape 2, image 2 de 2
      • With the corners lifted, take the opening tool and pry each corner off.
      • Repeat this for the corner diagonal from the initial corner.
      • Once both corners are pried off, gently take the back case off the device.
      Demander à FixBot
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Battery: étape 3, image 1 de 2 Amazon Fire HD 8 12th Gen Screen Replacement, Battery: étape 3, image 2 de 2
      • Using the iFixit opening tool, disconnect the battery from the circuit board.
      Demander à FixBot
    2. Amazon Fire HD 8 12th Gen Screen Replacement: étape 4, image 1 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 4, image 2 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 4, image 3 de 3
      • Slowly and gently, pull and remove the 3 adhesives under the old battery.
      • Remove all 3 by pulling the adhesive, signified by a black flap with white adhesive. You will know it is removed when the adhesive has come out from under the battery and you are now able to move the battery.
      Demander à FixBot
    3. Amazon Fire HD 8 12th Gen Screen Replacement: étape 5, image 1 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 5, image 2 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 5, image 3 de 3
      • Remove the old battery from the device using the opening tool.
      • If necessary, clean under your old battery and then insert the new battery with new adhesive to ensure the battery stays in place.
      Demander à FixBot
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Screen: étape 6, image 1 de 2 Amazon Fire HD 8 12th Gen Screen Replacement, Screen: étape 6, image 2 de 2
      • Start off by heating the edges of the screen to melt the adhesive.
      • Insert the opening picks between the screen and device.
      Demander à FixBot
    2. Amazon Fire HD 8 12th Gen Screen Replacement: étape 7, image 1 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 7, image 2 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 7, image 3 de 3
      • Slide the opening pick in between the screen and device, prying it just above the device.
      • Place the suction on the screen
      Demander à FixBot
    3. Amazon Fire HD 8 12th Gen Screen Replacement: étape 8, image 1 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 8, image 2 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 8, image 3 de 3
      • Gently pull the screen off using the suction and opening tool.
      Demander à FixBot
    4. Amazon Fire HD 8 12th Gen Screen Replacement: étape 9, image 1 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 9, image 2 de 3 Amazon Fire HD 8 12th Gen Screen Replacement: étape 9, image 3 de 3
      Outil utilisé dans cette étape :
      • Heat up the little black square with yellow orange tape around it on the back of the device, atop the motherboard.
      • Once heated, remove the little black square using tweezers. Unhooking the screen from the screen.
      • Pulling the suction cup, fully remove the screen from the device.
      Demander à FixBot
Rama Sura
Membre depuis le 02/13/23
454 Réputation
3 tutoriels rédigés
Équipe
University of Memphis, Team 1-1, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-1, Sneed Fall 2023
UM-SNEED-F23S1G1
4 membres
7 tutoriels rédigés
1 commentaire de tutoriel
Where can i buy a replacement screen?
Imfenway - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 32
30 derniers jours : 169
Total : 4,909
