Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Amazon Luna Controller Shell Replacement
Ce dont vous avez besoin
    1. Amazon Luna Controller Shell Replacement, Battery: étape 1, image 1 de 1
      • Flip the controller over so that the back panel is facing up.
      Demander à FixBot
      Ajouter un commentaire
    2. Amazon Luna Controller Shell Replacement: étape 2, image 1 de 3 Amazon Luna Controller Shell Replacement: étape 2, image 2 de 3 Amazon Luna Controller Shell Replacement: étape 2, image 3 de 3
      • Locate the latch on the back panel.
      • Pull down gently to open the compartment and expose the battery slots.
      • Remove batteries.
      Demander à FixBot
    1. Amazon Luna Controller Shell Replacement, Faceplate: étape 3, image 1 de 1
      • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
      Demander à FixBot
    2. Amazon Luna Controller Shell Replacement: étape 4, image 1 de 1
      • Hold the controller firmly.
      • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
      • Work slowly and carefully around all sides to avoid snapping the clips.
      Demander à FixBot
    3. Amazon Luna Controller Shell Replacement: étape 5, image 1 de 2 Amazon Luna Controller Shell Replacement: étape 5, image 2 de 2
      • Once all clips are released, lift the front plate away from the controller.
      Demander à FixBot
    1. Amazon Luna Controller Shell Replacement, Buttons: étape 6, image 1 de 2 Amazon Luna Controller Shell Replacement, Buttons: étape 6, image 2 de 2
      • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
      Demander à FixBot
    2. Amazon Luna Controller Shell Replacement: étape 7, image 1 de 2 Amazon Luna Controller Shell Replacement: étape 7, image 2 de 2
      • Gently pry along the seam that separates the two halves of the controller using an opening tool.
      • Work your way around the perimeter to carefully release the clips securing the two halves.
      Demander à FixBot
    3. Amazon Luna Controller Shell Replacement: étape 8, image 1 de 3 Amazon Luna Controller Shell Replacement: étape 8, image 2 de 3 Amazon Luna Controller Shell Replacement: étape 8, image 3 de 3
      • Lay the front of the controller shell downward.
      • Remove the rubber padding that keeps the buttons in place.
      • Remove the buttons from the shell housing.
      Demander à FixBot
    1. Amazon Luna Controller Shell Replacement, Joystick Cover: étape 9, image 1 de 2 Amazon Luna Controller Shell Replacement, Joystick Cover: étape 9, image 2 de 2
      • Gently pull the joystick thumbstick straight up to remove it from the controller.
      Demander à FixBot
    1. Amazon Luna Controller Shell Replacement, Shell: étape 10, image 1 de 2 Amazon Luna Controller Shell Replacement, Shell: étape 10, image 2 de 2
      • Gently grab the controller's circuitry and hold the bottom shell.
      • Pull the circuitry gently out from the shell.
      Demander à FixBot
Cade Queen
Membre depuis le 09/04/24
544 Réputation
5 tutoriels rédigés
Équipe
2 commentaires de tutoriel
After putting it together, did your B button work again? I can't get mines to function anymore. The joysticks are also moving around a lot on their on.
SophisticatedCheese - Réponse Partager
I would check your reassembly and make sure none of the pads are damaged under the buttons
Ethan Phillips - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 35
Total : 385
