Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Apple IIc Floppy Drive Replacement
Ce dont vous avez besoin
  1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: étape 1, image 1 de 2 Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: étape 1, image 2 de 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. Apple IIc Floppy Drive Replacement: étape 2, image 1 de 2 Apple IIc Floppy Drive Replacement: étape 2, image 2 de 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    Demander à FixBot
  3. Apple IIc Floppy Drive Replacement: étape 3, image 1 de 2 Apple IIc Floppy Drive Replacement: étape 3, image 2 de 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    Demander à FixBot
  4. Apple IIc Floppy Drive Replacement: étape 4, image 1 de 2 Apple IIc Floppy Drive Replacement: étape 4, image 2 de 2
    • Lift the handle straight up to remove.
    Demander à FixBot
  5. Apple IIc Floppy Drive Replacement, Keyboard: étape 5, image 1 de 2 Apple IIc Floppy Drive Replacement, Keyboard: étape 5, image 2 de 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
    Demander à FixBot
  6. Apple IIc Floppy Drive Replacement, Floppy Drive: étape 6, image 1 de 2 Apple IIc Floppy Drive Replacement, Floppy Drive: étape 6, image 2 de 2
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
    Demander à FixBot
  7. Apple IIc Floppy Drive Replacement: étape 7, image 1 de 3 Apple IIc Floppy Drive Replacement: étape 7, image 2 de 3 Apple IIc Floppy Drive Replacement: étape 7, image 3 de 3
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
    Demander à FixBot
  8. Apple IIc Floppy Drive Replacement: étape 8, image 1 de 2 Apple IIc Floppy Drive Replacement: étape 8, image 2 de 2
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
    Demander à FixBot
  9. Apple IIc Floppy Drive Replacement: étape 9, image 1 de 2 Apple IIc Floppy Drive Replacement: étape 9, image 2 de 2
    • Carefully lift the floppy drive cage straight up to remove it.
    Demander à FixBot
  10. Apple IIc Floppy Drive Replacement: étape 10, image 1 de 2 Apple IIc Floppy Drive Replacement: étape 10, image 2 de 2
    • Lift the floppy drive straight up to remove.
    Demander à FixBot
8 autres ont terminé cette réparation.
Alexandria Weinberg
Membre depuis le 10/06/11
601 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 40
Total : 6,284
