Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Apple PowerBook G3 400 RAM Replacement
Ce dont vous avez besoin
    1. Apple PowerBook G3 400 RAM Replacement, Keyboard: étape 1, image 1 de 1
      • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
      • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
      Demander à FixBot
      Ajouter un commentaire
    2. Apple PowerBook G3 400 RAM Replacement: étape 2, image 1 de 1
      • Pull the keyboard ribbon vertically from the logic board to release connection.
      • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
      • Remove battery and CD/DVD drives before proceeding any further.
      Demander à FixBot
    3. Apple PowerBook G3 400 RAM Replacement: étape 3, image 1 de 1
      • Your computer should look approximately like this.
      Demander à FixBot
    1. Apple PowerBook G3 400 RAM Replacement, RAM: étape 4, image 1 de 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
      • Lift the heat shield up and toward you.
      Demander à FixBot
    2. Apple PowerBook G3 400 RAM Replacement: étape 5, image 1 de 1
      • Pull the PRAM battery cable vertically upward to disconnect it.
      • Remove the battery by pulling up and to the left.
      Demander à FixBot
    3. Apple PowerBook G3 400 RAM Replacement: étape 6, image 1 de 1
      • Remove the two T8 Torx screws that attach the heat sink to the processor.
      • Remove the long silver Phillips #1 screw from the heat sink.
      Demander à FixBot
    4. Apple PowerBook G3 400 RAM Replacement: étape 7, image 1 de 1
      • Lift up the heat sink unit from the left side and remove.
      Demander à FixBot
    5. Apple PowerBook G3 400 RAM Replacement: étape 8, image 1 de 1
      • Lift the processor on the right side and pull directly up.
      • The RAM chips should be in the slots on the processor.
      Demander à FixBot
    6. Apple PowerBook G3 400 RAM Replacement: étape 9, image 1 de 1
      • After removing the RAM, your laptop should now look like this.
      Demander à FixBot
2 autres ont terminé cette réparation.
Ian
Membre depuis le 04/18/11
57 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-2, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 25
Total : 2,517
