Aller au contenu principal
Arlo Ultra 2 Camera Lens Replacement
Ce dont vous avez besoin
  1. Arlo Ultra 2 Camera Lens Replacement, Battery: étape 1, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement, Battery: étape 1, image 2 de 2
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Camera Lens Replacement: étape 2, image 1 de 1
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Camera Lens Replacement, Speaker: étape 3, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement, Speaker: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Camera Lens Replacement: étape 4, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement: étape 4, image 2 de 2
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Camera Lens Replacement: étape 5, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement: étape 5, image 2 de 2
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Camera Lens Replacement: étape 6, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement: étape 6, image 2 de 2
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Camera Lens Replacement: étape 7, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement: étape 7, image 2 de 2
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Camera Lens Replacement: étape 8, image 1 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 8, image 2 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 8, image 3 de 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Camera Lens Replacement: étape 9, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement: étape 9, image 2 de 2
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Camera Lens Replacement: étape 10, image 1 de 1
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Camera Lens Replacement: étape 11, image 1 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 11, image 2 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 11, image 3 de 3
    • Feed the speaker cable through the opening to remove the speaker.
  12. Arlo Ultra 2 Camera Lens Replacement, Camera Lens: étape 12, image 1 de 3 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: étape 12, image 2 de 3 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: étape 12, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 5.0 mm screws from both sides of the metal plate.
    • Pry the metal plate away from circuit board underneath.
    • There is a small amount of blue putty in between the metal plate and the circuit board.
  13. Arlo Ultra 2 Camera Lens Replacement: étape 13, image 1 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 13, image 2 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 13, image 3 de 3
    • Use a spudger to remove the entire green circuit board with lens attached.
  14. Arlo Ultra 2 Camera Lens Replacement: étape 14, image 1 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 14, image 2 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 14, image 3 de 3
    • Use a Phillips #00 screwdriver to remove three black 5.0 mm screws from back of the circuit board.
    • Separate the lens from the circuit board.
    • There is a small cord connecting the lens and circuit board.
  15. Arlo Ultra 2 Camera Lens Replacement: étape 15, image 1 de 2 Arlo Ultra 2 Camera Lens Replacement: étape 15, image 2 de 2
    • Use a spudger to carefully push on each side of the white cable connector to remove it from the socket and separate the camera lens from the board.
  16. Arlo Ultra 2 Camera Lens Replacement: étape 16, image 1 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 16, image 2 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 16, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws from the side of the lens body.
  17. Arlo Ultra 2 Camera Lens Replacement: étape 17, image 1 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 17, image 2 de 3 Arlo Ultra 2 Camera Lens Replacement: étape 17, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the blunt tweezers to remove the focus motor control insert from the main lens body.
Xavier Feaster-Rivera
Membre depuis le 01/23/23
449 Réputation
2 tutoriels rédigés
6 commentaires
Any ideas on where to get the lens ordered?
Jerald Buechler - Réponse
I called Arlo and they said they don’t sell a replacement. I couldn’t find it anywhere online either. Does anybody know where to get a replacement?
Barry Bonds - Réponse
My was badly scratched and I would like to replace the lens but I can't find any arlo lenses for sale. Plenty other ones but not arlo one.
Karol jar - Réponse
Has anyon found where to buy a replacement lens? Mine is cracked and unusable without a new lens.
Digit Holder - Réponse
My Arlo ultra lens fell out and smashed whilst swapping out the battery, the inertia from the tap dislodged the poorly fix lens, now I cant find a replacement
Paul Heslin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 40
Total : 751
