Aller au contenu principal
Arlo Ultra 2 Speaker Replacement
Ce dont vous avez besoin
  1. Arlo Ultra 2 Speaker Replacement, Battery: étape 1, image 1 de 2 Arlo Ultra 2 Speaker Replacement, Battery: étape 1, image 2 de 2
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Speaker Replacement: étape 2, image 1 de 1
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Speaker Replacement, Speaker: étape 3, image 1 de 2 Arlo Ultra 2 Speaker Replacement, Speaker: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Speaker Replacement: étape 4, image 1 de 2 Arlo Ultra 2 Speaker Replacement: étape 4, image 2 de 2
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Speaker Replacement: étape 5, image 1 de 2 Arlo Ultra 2 Speaker Replacement: étape 5, image 2 de 2
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Speaker Replacement: étape 6, image 1 de 2 Arlo Ultra 2 Speaker Replacement: étape 6, image 2 de 2
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Speaker Replacement: étape 7, image 1 de 2 Arlo Ultra 2 Speaker Replacement: étape 7, image 2 de 2
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Speaker Replacement: étape 8, image 1 de 3 Arlo Ultra 2 Speaker Replacement: étape 8, image 2 de 3 Arlo Ultra 2 Speaker Replacement: étape 8, image 3 de 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Speaker Replacement: étape 9, image 1 de 2 Arlo Ultra 2 Speaker Replacement: étape 9, image 2 de 2
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Speaker Replacement: étape 10, image 1 de 1
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Speaker Replacement: étape 11, image 1 de 3 Arlo Ultra 2 Speaker Replacement: étape 11, image 2 de 3 Arlo Ultra 2 Speaker Replacement: étape 11, image 3 de 3
    • Feed the speaker cable through the opening to remove the speaker.
Xavier Feaster-Rivera
Membre depuis le 01/23/23
449 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 119
