Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus A52F RAM Replacement
Ce dont vous avez besoin
  1. Asus A52F RAM Replacement, Battery: étape 1, image 1 de 2 Asus A52F RAM Replacement, Battery: étape 1, image 2 de 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus A52F RAM Replacement: étape 2, image 1 de 2 Asus A52F RAM Replacement: étape 2, image 2 de 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
    Demander à FixBot
  3. Asus A52F RAM Replacement, Lower Case: étape 3, image 1 de 3 Asus A52F RAM Replacement, Lower Case: étape 3, image 2 de 3 Asus A52F RAM Replacement, Lower Case: étape 3, image 3 de 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
    Demander à FixBot
  4. Asus A52F RAM Replacement: étape 4, image 1 de 2 Asus A52F RAM Replacement: étape 4, image 2 de 2
    • Slide the back panel away and remove the panel.
    Demander à FixBot
  5. Asus A52F RAM Replacement, RAM: étape 5, image 1 de 1
    • Gently push the metal retaining arms away from the center of the RAM module.
    Demander à FixBot
  6. Asus A52F RAM Replacement: étape 6, image 1 de 3 Asus A52F RAM Replacement: étape 6, image 2 de 3 Asus A52F RAM Replacement: étape 6, image 3 de 3
    • The RAM should now be sticking up at a 30° angle.
    • Carefully grab the top edge of the RAM and gently pull it it out at it's angle.
    Demander à FixBot
  7. Asus A52F RAM Replacement: étape 7, image 1 de 1
    • Repeat removal process for the RAM underneath.
    Demander à FixBot
  8. Asus A52F RAM Replacement: étape 8, image 1 de 2 Asus A52F RAM Replacement: étape 8, image 2 de 2
    • To insert new RAM line up notch in the connector and slide in at a 30° angle.
    • RAM only goes in one way!
    • Push straight down until the metal clips on both sides click into place
    Demander à FixBot
3 autres ont terminé cette réparation.
Bradley Varnum
Membre depuis le 03/09/17
345 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S5-G1, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G1
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 24
Total : 1,297
