Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus Q500A RAM Replacement
Ce dont vous avez besoin
  1. Asus Q500A RAM Replacement, RAM: étape 1, image 1 de 2 Asus Q500A RAM Replacement, RAM: étape 1, image 2 de 2
    • Flip device upside-down.
    • Remove back-plate by unscrewing the two screws on either side of the back-plate.
    • Remove the plastic cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus Q500A RAM Replacement: étape 2, image 1 de 1
    • Depending on the model of the device, there will either be one or two sticks of ram.
    • There are two metal brackets holding each ram stick in.
    • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
    Demander à FixBot
  3. Asus Q500A RAM Replacement: étape 3, image 1 de 2 Asus Q500A RAM Replacement: étape 3, image 2 de 2
    • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
    Demander à FixBot
  4. Asus Q500A RAM Replacement: étape 4, image 1 de 1
    • To insert the ram line up the ram stick and the slot.
    • Next you will have to push the ram down until it snaps into place.
    • Be careful not to do this too hard, as it can break the ram.
    • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
    Demander à FixBot
cameron
Membre depuis le 02/15/17
319 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 12-5, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 27
Total : 1,089
