Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus Q525U RAM Replacement
Ce dont vous avez besoin
  1. Asus Q525U RAM Replacement, Back Cover: étape 1, image 1 de 3 Asus Q525U RAM Replacement, Back Cover: étape 1, image 2 de 3 Asus Q525U RAM Replacement, Back Cover: étape 1, image 3 de 3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus Q525U RAM Replacement: étape 2, image 1 de 3 Asus Q525U RAM Replacement: étape 2, image 2 de 3 Asus Q525U RAM Replacement: étape 2, image 3 de 3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    Demander à FixBot
  3. Asus Q525U RAM Replacement: étape 3, image 1 de 3 Asus Q525U RAM Replacement: étape 3, image 2 de 3 Asus Q525U RAM Replacement: étape 3, image 3 de 3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    Demander à FixBot
  4. Asus Q525U RAM Replacement, RAM: étape 4, image 1 de 1
    • Position the flat end of the Spudger under one of the corners on the RAM cover and pry it up slightly.
    • Move the spudger around the periphery of the cover to lift the cover up.
    Demander à FixBot
  5. Asus Q525U RAM Replacement: étape 5, image 1 de 1
    • Lift the RAM cover off.
    • The RAM should now be fully exposed.
    Demander à FixBot
  6. Asus Q525U RAM Replacement: étape 6, image 1 de 3 Asus Q525U RAM Replacement: étape 6, image 2 de 3 Asus Q525U RAM Replacement: étape 6, image 3 de 3
    • Using a spudger or your fingers, gently pull the metal brackets away from the RAM.
    • After pulling both brackets away from the component, the RAM should release at an upward angle (allowing for removal and replacement).
    Demander à FixBot
  7. Asus Q525U RAM Replacement: étape 7, image 1 de 1
    • Slide the RAM stick out of the socket.
    Demander à FixBot
Stewart Crandall
Membre depuis le 02/22/22
613 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 2-5, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 25
Total : 1,592
