Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus ROG Ally Heatsink Replacement
Ce dont vous avez besoin
    1. Asus ROG Ally Heatsink Replacement, Prepare your device for disassembly: étape 1, image 1 de 3 Asus ROG Ally Heatsink Replacement, Prepare your device for disassembly: étape 1, image 2 de 3 Asus ROG Ally Heatsink Replacement, Prepare your device for disassembly: étape 1, image 3 de 3
      • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Completely power off your device and unplug all cables.
      • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
      Demander à FixBot
      Ajouter un commentaire
    1. Asus ROG Ally Heatsink Replacement, Unfasten the back cover: étape 2, image 1 de 2 Asus ROG Ally Heatsink Replacement, Unfasten the back cover: étape 2, image 2 de 2
      Outil utilisé dans cette étape :
      FixMat
      $36.95
      • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
      • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
      • Don't try to remove this screw.
      Demander à FixBot
    2. Asus ROG Ally Heatsink Replacement, Insert an opening pick: étape 3, image 1 de 3 Asus ROG Ally Heatsink Replacement, Insert an opening pick: étape 3, image 2 de 3 Asus ROG Ally Heatsink Replacement, Insert an opening pick: étape 3, image 3 de 3
      • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
      • Angle the pick upward and push it under the back cover.
      Demander à FixBot
    3. Asus ROG Ally Heatsink Replacement, Release the back cover's clips: étape 4, image 1 de 3 Asus ROG Ally Heatsink Replacement, Release the back cover's clips: étape 4, image 2 de 3 Asus ROG Ally Heatsink Replacement, Release the back cover's clips: étape 4, image 3 de 3
      • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
      • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
      • Keep the pick at an upward angle under the back cover to help release the clips.
      Demander à FixBot
    4. Asus ROG Ally Heatsink Replacement, Remove the back cover: étape 5, image 1 de 3 Asus ROG Ally Heatsink Replacement, Remove the back cover: étape 5, image 2 de 3 Asus ROG Ally Heatsink Replacement, Remove the back cover: étape 5, image 3 de 3
      • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
      • Remove the back cover.
      • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
      Demander à FixBot
    1. Asus ROG Ally Heatsink Replacement, Remove the plastic cover: étape 6, image 1 de 3 Asus ROG Ally Heatsink Replacement, Remove the plastic cover: étape 6, image 2 de 3 Asus ROG Ally Heatsink Replacement, Remove the plastic cover: étape 6, image 3 de 3
      • Use your fingers to peel up and remove the black plastic cover between the fans.
      • Put the cover aside—you'll use it during reassembly.
      Demander à FixBot
    2. Asus ROG Ally Heatsink Replacement, Unlatch the locking bar: étape 7, image 1 de 3 Asus ROG Ally Heatsink Replacement, Unlatch the locking bar: étape 7, image 2 de 3 Asus ROG Ally Heatsink Replacement, Unlatch the locking bar: étape 7, image 3 de 3
      • A metal locking bar secures the top edge of the battery connector
      • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
      Demander à FixBot
    3. Asus ROG Ally Heatsink Replacement, Disconnect the battery: étape 8, image 1 de 3 Asus ROG Ally Heatsink Replacement, Disconnect the battery: étape 8, image 2 de 3 Asus ROG Ally Heatsink Replacement, Disconnect the battery: étape 8, image 3 de 3
      • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
      • Insert the flat end of a spudger under the center of the battery connector.
      • Lift the connector straight up and out of its socket to disconnect the battery.
      • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
      Demander à FixBot
    1. Asus ROG Ally Heatsink Replacement, Separate the fan tape: étape 9, image 1 de 3 Asus ROG Ally Heatsink Replacement, Separate the fan tape: étape 9, image 2 de 3 Asus ROG Ally Heatsink Replacement, Separate the fan tape: étape 9, image 3 de 3
      • Two pieces of tape secure the upper edges of the fans to the heatsink foam.
      • Insert the point of a spudger between the tape on the upper edge of one of the fans and the heatsink foam.
      • Slide the spudger under the length of the tape to separate it from the foam.
      Demander à FixBot
    2. Asus ROG Ally Heatsink Replacement: étape 10, image 1 de 3 Asus ROG Ally Heatsink Replacement: étape 10, image 2 de 3 Asus ROG Ally Heatsink Replacement: étape 10, image 3 de 3
      • Repeat the previous step to separate the other piece of fan tape.
      • During reassembly, firmly press both pieces of tape back onto the foam.
      Demander à FixBot
    3. Asus ROG Ally Heatsink Replacement, Unfasten the heatsink: étape 11, image 1 de 2 Asus ROG Ally Heatsink Replacement, Unfasten the heatsink: étape 11, image 2 de 2
      • Use a Phillips #0 screwdriver to fully loosen the four captive screws securing the heatsink. Don't try to remove these screws.
      • The bottom left screw has a warning sticker on it. Pierce through it with your screwdriver or use tweezers to remove it.
      • During reassembly, tighten the screws in order (1, 2, 3, 4) based on the number stamped next to each screw.
      Demander à FixBot
    4. Asus ROG Ally Heatsink Replacement, Remove the heatsink: étape 12, image 1 de 3 Asus ROG Ally Heatsink Replacement, Remove the heatsink: étape 12, image 2 de 3 Asus ROG Ally Heatsink Replacement, Remove the heatsink: étape 12, image 3 de 3
      • Lift the bottom edge of the heatsink and remove it.
      • You may feel some resistance, as thermal paste bonds the heatsink to the CPU.
      Demander à FixBot
    5. Asus ROG Ally Heatsink Replacement, Replace the thermal paste: étape 13, image 1 de 3 Asus ROG Ally Heatsink Replacement, Replace the thermal paste: étape 13, image 2 de 3 Asus ROG Ally Heatsink Replacement, Replace the thermal paste: étape 13, image 3 de 3
      • Before installing a heatsink, follow this guide to clean both the CPU and heatsink and apply new thermal paste.
      Demander à FixBot
5 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
199 377 Réputation
1 243 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
66 365 tutoriels rédigés
1 commentaire de tutoriel
What kind of Thermal Paste does ROG Ally use? Just normal thermal paste or some kind of phase-change thermal pad?
Rizky Saputra - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 41
30 derniers jours : 217
Total : 4,704
