Aller au contenu principal
Asus ROG G751JL-BSI7T28 Fan Replacement
Ce dont vous avez besoin
  1. Asus ROG G751JL-BSI7T28 Fan Replacement, Back Panel: étape 1, image 1 de 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Fan Replacement: étape 2, image 1 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 2, image 2 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 2, image 3 de 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: étape 3, image 1 de 2 Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: étape 3, image 2 de 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Fan Replacement: étape 4, image 1 de 2 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 4, image 2 de 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Fan Replacement: étape 5, image 1 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 5, image 2 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 5, image 3 de 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Fan Replacement: étape 6, image 1 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 6, image 2 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 6, image 3 de 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Fan Replacement: étape 7, image 1 de 2 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 7, image 2 de 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: étape 8, image 1 de 2 Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: étape 8, image 2 de 2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: étape 9, image 1 de 2 Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: étape 9, image 2 de 2
    • Remove the fan's power cable by pulling carefully outward towards the fan.
  10. Asus ROG G751JL-BSI7T28 Fan Replacement: étape 10, image 1 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 10, image 2 de 3 Asus ROG G751JL-BSI7T28 Fan Replacement: étape 10, image 3 de 3
    • Remove the 5mm Phillips #00 screw.
    • Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
    • Remove the fan from the laptop.
Kristen Gismondi
Membre depuis le 11/12/14
85 242 Réputation
215 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 067 tutoriels rédigés
Un commentaire
What's the fan model?
Andres Landazuri - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 19
Total : 706
