Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus UL80J Key Replacement
Ce dont vous avez besoin
  1. Asus UL80J Key Replacement, Battery: étape 1, image 1 de 1
    • Place laptop face down with battery facing up.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus UL80J Key Replacement: étape 2, image 1 de 1
    • Slide unlock button to the right.
    Demander à FixBot
  3. Asus UL80J Key Replacement: étape 3, image 1 de 3 Asus UL80J Key Replacement: étape 3, image 2 de 3 Asus UL80J Key Replacement: étape 3, image 3 de 3
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
    Demander à FixBot
  4. Asus UL80J Key Replacement, Keyboard: étape 4, image 1 de 1
    • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
    Demander à FixBot
  5. Asus UL80J Key Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Gently pry the keyboard up. This will allow you to unclip the keyboard.
    • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
    • Unclipping sounds are normal.
    Demander à FixBot
    • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
    Demander à FixBot
  6. Asus UL80J Key Replacement: étape 7, image 1 de 1
    • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
    • Remove the tape from the ribbon cable if needed and remove the keyboard.
    Demander à FixBot
  7. Asus UL80J Key Replacement, Key: étape 8, image 1 de 2 Asus UL80J Key Replacement, Key: étape 8, image 2 de 2
    • Gently insert the plastic opening tool between the key cap and the hinge. Slowly push the screwdriver up. The key should pop up easily.
    Demander à FixBot
    • Clean the surface underneath the key with a soft brush or condensed air.
    Demander à FixBot
    • Insert the new key in place of the old key. Ensure the clipping sound occurs.
    Demander à FixBot
Kateryna Turchenko
Membre depuis le 02/20/17
201 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S2-G4, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S2-G4, Lacy Spring 2017
USFT-LACY-S17S2G4
3 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 555
