Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus UL80J Screen Replacement
Ce dont vous avez besoin
  1. Asus UL80J Screen Replacement, Battery: étape 1, image 1 de 1
    • Place laptop face down with battery facing up.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus UL80J Screen Replacement: étape 2, image 1 de 1
    • Slide unlock button to the right.
    Demander à FixBot
  3. Asus UL80J Screen Replacement: étape 3, image 1 de 3 Asus UL80J Screen Replacement: étape 3, image 2 de 3 Asus UL80J Screen Replacement: étape 3, image 3 de 3
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
    Demander à FixBot
  4. Asus UL80J Screen Replacement, Screen: étape 4, image 1 de 3 Asus UL80J Screen Replacement, Screen: étape 4, image 2 de 3 Asus UL80J Screen Replacement, Screen: étape 4, image 3 de 3
    • Flip laptop back over and open it so that the screen faces you. Several rubber cushions hide screws around the bezel (surrounding frame). Remove these first to get to the screws underneath. The two bottom covers are stickers. Then remove all screws holding the bezel in place.
    • There will be four 3 mm screws located on the top and two 5 mm screws located on the bottom of the bezel.
    Demander à FixBot
  5. Asus UL80J Screen Replacement: étape 5, image 1 de 2 Asus UL80J Screen Replacement: étape 5, image 2 de 2
    • Next, completely remove the bezel using a plastic opening tool to work your way around while gently prying it from the LCD. If it does not come off with a moderate amount of force check that you did not miss any screws.
    Demander à FixBot
  6. Asus UL80J Screen Replacement: étape 6, image 1 de 1
    • Unscrew the four 3 mm screws that hold the mounting brackets for the screen to the backing.
    Demander à FixBot
  7. Asus UL80J Screen Replacement: étape 7, image 1 de 1
    • Gently lay the screen on the keyboard and remove the tape over the connection. You can then disconnect the screen.
    Demander à FixBot
To reassemble your device, follow these instructions in reverse order. It is a good idea to check that the new screen works before reattaching the bezel.
Loren Plopper
Membre depuis le 02/19/17
213 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S2-G4, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S2-G4, Lacy Spring 2017
USFT-LACY-S17S2G4
3 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 36
Total : 588
