Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus X501A-RH31 Keyboard Replacement
Ce dont vous avez besoin
  1. Asus X501A-RH31 Keyboard  Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop over so that the back is facing upwards.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus X501A-RH31 Keyboard  Replacement: étape 2, image 1 de 1
    • To unlock the left tab, make sure the tab on the left has red showing.
    Demander à FixBot
  3. Asus X501A-RH31 Keyboard  Replacement: étape 3, image 1 de 2 Asus X501A-RH31 Keyboard  Replacement: étape 3, image 2 de 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
    Demander à FixBot
  4. Asus X501A-RH31 Keyboard  Replacement, Keyboard: étape 4, image 1 de 2 Asus X501A-RH31 Keyboard  Replacement, Keyboard: étape 4, image 2 de 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
    Demander à FixBot
  5. Asus X501A-RH31 Keyboard  Replacement: étape 5, image 1 de 1
    • Turn the laptop over and open the top so the keyboard is facing you.
    Demander à FixBot
  6. Asus X501A-RH31 Keyboard  Replacement: étape 6, image 1 de 2 Asus X501A-RH31 Keyboard  Replacement: étape 6, image 2 de 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
    Demander à FixBot
  7. Asus X501A-RH31 Keyboard  Replacement: étape 7, image 1 de 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
    Demander à FixBot
  8. Asus X501A-RH31 Keyboard  Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
    Demander à FixBot
Romana Hruby
Membre depuis le 10/20/17
596 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G3, Bailey Fall 2017
UMASSD-BAILEY-F17S3G3
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 26
Total : 1,552
