Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus X551CA Power Button Replacement
Ce dont vous avez besoin
  1. Asus X551CA Power Button Replacement, Keyboard Plate Cover: étape 1, image 1 de 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Demander à FixBot
    Ajouter un commentaire
  2. Asus X551CA Power Button Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Demander à FixBot
  3. Asus X551CA Power Button Replacement: étape 3, image 1 de 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Demander à FixBot
  4. Asus X551CA Power Button Replacement: étape 4, image 1 de 3 Asus X551CA Power Button Replacement: étape 4, image 2 de 3 Asus X551CA Power Button Replacement: étape 4, image 3 de 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Demander à FixBot
  5. Asus X551CA Power Button Replacement: étape 5, image 1 de 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Demander à FixBot
  6. Asus X551CA Power Button Replacement, Power Button: étape 6, image 1 de 1
    • Locate the power button in the corner of the keyboard plate cover.
    • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
    Demander à FixBot
  7. Asus X551CA Power Button Replacement: étape 7, image 1 de 1
    • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
    Demander à FixBot
  8. Asus X551CA Power Button Replacement: étape 8, image 1 de 1
    • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
    Demander à FixBot
7 autres ont terminé cette réparation.
Josh
Membre depuis le 04/10/14
2 970 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 7-22, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 membres
15 tutoriels rédigés
1 commentaire de tutoriel
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 39
Total : 13,353
