Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus X751L Wireless Card Replacement
Ce dont vous avez besoin
  1. Asus X751L Wireless Card Replacement, Keyboard: étape 1, image 1 de 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus X751L Wireless Card Replacement: étape 2, image 1 de 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
    Demander à FixBot
  3. Asus X751L Wireless Card Replacement: étape 3, image 1 de 3 Asus X751L Wireless Card Replacement: étape 3, image 2 de 3 Asus X751L Wireless Card Replacement: étape 3, image 3 de 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
    Demander à FixBot
  4. Asus X751L Wireless Card Replacement, Wireless Card: étape 4, image 1 de 1
    • Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
    Demander à FixBot
  5. Asus X751L Wireless Card Replacement: étape 5, image 1 de 1
    • Using your fingers, lightly lift up on the black and white antenna cords.
    Demander à FixBot
  6. Asus X751L Wireless Card Replacement: étape 6, image 1 de 1
    • With your fingers lightly pull the wireless card out of the slot.
    • Make sure to keep the card parallel with the motherboard when removing from the slot.
    Demander à FixBot
3 autres ont terminé cette réparation.
Matthew Martin
Membre depuis le 02/02/17
217 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 17-2, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 membres
5 tutoriels rédigés
1 commentaire de tutoriel
I feel the existing WiFi card is not very good. Is there is better one I can get for the Asus X751L?
July 3, 2023.
cookbake2 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 37
Total : 2,815
