Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Atmega328P Microcontroller Replacement for Arduino Board
Ce dont vous avez besoin
    1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: étape 1, image 1 de 1
      • Place the Arduino UNO R3 board on a flat clean surface.
      Demander à FixBot
      Ajouter un commentaire
    2. Atmega328P Microcontroller Replacement for Arduino Board: étape 2, image 1 de 2 Atmega328P Microcontroller Replacement for Arduino Board: étape 2, image 2 de 2
      • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
      • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
      Demander à FixBot
    3. Atmega328P Microcontroller Replacement for Arduino Board: étape 3, image 1 de 2 Atmega328P Microcontroller Replacement for Arduino Board: étape 3, image 2 de 2
      • Repeat the same process on the other side.
      • Lift both sides evenly to prevent any damage to the pins.
      Demander à FixBot
    4. Atmega328P Microcontroller Replacement for Arduino Board: étape 4, image 1 de 3 Atmega328P Microcontroller Replacement for Arduino Board: étape 4, image 2 de 3 Atmega328P Microcontroller Replacement for Arduino Board: étape 4, image 3 de 3
      • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
      Demander à FixBot
    5. Atmega328P Microcontroller Replacement for Arduino Board: étape 5, image 1 de 1
      • Remove replacement microcontroller out of packaging.
      Demander à FixBot
    6. Atmega328P Microcontroller Replacement for Arduino Board: étape 6, image 1 de 1
      • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
      • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
      Demander à FixBot
    7. Atmega328P Microcontroller Replacement for Arduino Board: étape 7, image 1 de 2 Atmega328P Microcontroller Replacement for Arduino Board: étape 7, image 2 de 2
      • Gently press the microcontroller into the dip socket
      Demander à FixBot
3 autres ont terminé cette réparation.
Youssef Qteshat
Membre depuis le 01/26/23
217 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 5-5, Morris Winter 2023 Membre de l'équipe UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 55
Total : 1,461
