Aller au contenu principal
Pour réparer ensemble - Je crée un compte
August Smart Lock Accelerometer Replacement
Ce dont vous avez besoin
  1. August Smart Lock Accelerometer Replacement, Accelerometer: étape 1, image 1 de 3 August Smart Lock Accelerometer Replacement, Accelerometer: étape 1, image 2 de 3 August Smart Lock Accelerometer Replacement, Accelerometer: étape 1, image 3 de 3
    • Flip device over so the black bottom is facing you.
    • Undo latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
    Demander à FixBot
    Ajouter un commentaire
  2. August Smart Lock Accelerometer Replacement: étape 2, image 1 de 3 August Smart Lock Accelerometer Replacement: étape 2, image 2 de 3 August Smart Lock Accelerometer Replacement: étape 2, image 3 de 3
    • Grab the gears and lift them up to remove from the device
    Demander à FixBot
  3. August Smart Lock Accelerometer Replacement: étape 3, image 1 de 3 August Smart Lock Accelerometer Replacement: étape 3, image 2 de 3 August Smart Lock Accelerometer Replacement: étape 3, image 3 de 3
    • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
    • Disconnect the speaker plug from the motherboard
    • Disconnect the battery plugs from the motherboard.
    Demander à FixBot
  4. August Smart Lock Accelerometer Replacement: étape 4, image 1 de 1
    • Once the speaker is disconnected, remove the back cover.
    • Lift up the motherboard and motor assembly out of the device.
    Demander à FixBot
  5. August Smart Lock Accelerometer Replacement: étape 5, image 1 de 2 August Smart Lock Accelerometer Replacement: étape 5, image 2 de 2
    • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
    • Lift up the black tab to remove the ribbon from the motherboard.
    Demander à FixBot
8 autres ont terminé cette réparation.
William Fink
Membre depuis le 09/26/17
841 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S11-G6, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 membres
6 tutoriels rédigés
7 commentaires de tutoriel
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Réponse Partager
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Réponse Partager
Same as above…. where to locate an accelerometer??
osallabe - Réponse Partager
Did anyone find out where to buy the part?
LBurd - Réponse Partager
Where can I find one
Jeff Wasilewski - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 60
Total : 8,853
