Aller au contenu principal
Pour réparer ensemble - Je crée un compte
August Smart Lock Gear Replacement
Ce dont vous avez besoin
    1. August Smart Lock Gear Replacement, Gear: étape 1, image 1 de 3 August Smart Lock Gear Replacement, Gear: étape 1, image 2 de 3 August Smart Lock Gear Replacement, Gear: étape 1, image 3 de 3
      • Flip the device over so the metal plate is facing you.
      • Undo the latches on the side to remove the metal plate.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
      Demander à FixBot
      Ajouter un commentaire
    2. August Smart Lock Gear Replacement: étape 2, image 1 de 3 August Smart Lock Gear Replacement: étape 2, image 2 de 3 August Smart Lock Gear Replacement: étape 2, image 3 de 3
      • Lift the cover off the device and set to the side.
      • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
      • Remove the gears as shown.
      Demander à FixBot
12 autres ont terminé cette réparation.
William Fink
Membre depuis le 09/26/17
841 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S11-G6, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 membres
6 tutoriels rédigés
8 commentaires de tutoriel
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Réponse Partager
Any tips on where to get replacement gears?
Byron H - Réponse Partager
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Réponse Partager
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante - Réponse Partager
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 65
Total : 14,055
