Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Axess SPBT1031 Subwoofer Replacement
Ce dont vous avez besoin
    1. Axess SPBT1031 Subwoofer Replacement, Subwoofer: étape 1, image 1 de 1
      • Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
      • Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
      • Do not remove the plate yet.
      Demander à FixBot
      Ajouter un commentaire
    2. Axess SPBT1031 Subwoofer Replacement: étape 2, image 1 de 1
      • Use a metal spudger to remove the mesh speaker cover by wedging the narrow end into the center of the outer edge of the mesh touching the red plate.
      Demander à FixBot
    3. Axess SPBT1031 Subwoofer Replacement: étape 3, image 1 de 2 Axess SPBT1031 Subwoofer Replacement: étape 3, image 2 de 2
      • Remove four 5.5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
      • For subwoofer replacement there will be four screws to remove and four bolts as well. The bolts are used for alignment and cannot be removed.
      Demander à FixBot
    4. Axess SPBT1031 Subwoofer Replacement: étape 4, image 1 de 1
      Outil utilisé dans cette étape :
      • If the screws are difficult to remove, use the tweezers to twist and pick them out.
      Demander à FixBot
    5. Axess SPBT1031 Subwoofer Replacement: étape 5, image 1 de 1
      • Separate the red plate from the black face plate by removing the black plate from the tube and pushing on the inside of the subwoofer.
      • Be careful not to damage the black face plate or red plate as you pull them apart.
      • You may place the black faceplate back on the tube, but do not screw it back in yet.
      Demander à FixBot
    6. Axess SPBT1031 Subwoofer Replacement: étape 6, image 1 de 2 Axess SPBT1031 Subwoofer Replacement: étape 6, image 2 de 2
      • To remove the the wires from the subwoofer terminals, use a soldering iron to reheat the solder at each of the four points of connection.
      Demander à FixBot
    7. Axess SPBT1031 Subwoofer Replacement: étape 7, image 1 de 1
      Desoldering Pump
      $3.99
      Demander à FixBot
    8. Axess SPBT1031 Subwoofer Replacement: étape 8, image 1 de 1
      • Remove the old subwoofer.
      • Connect the brown wires to the positive terminals and the black ones to the negative terminals when re-soldering.
      Demander à FixBot
2 autres ont terminé cette réparation.
Équipe
UMass Dartmouth, Team 8-6, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-6, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G6
3 membres
24 tutoriels rédigés
1 commentaire de tutoriel
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
Ramon lopez - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 26
Total : 2,051
