Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Azpen A720 Battery Replacement
Ce dont vous avez besoin
    1. Azpen A720 Battery Replacement, Back Cover: étape 1, image 1 de 2 Azpen A720 Battery Replacement, Back Cover: étape 1, image 2 de 2
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      Demander à FixBot
      Ajouter un commentaire
    2. Azpen A720 Battery Replacement: étape 2, image 1 de 3 Azpen A720 Battery Replacement: étape 2, image 2 de 3 Azpen A720 Battery Replacement: étape 2, image 3 de 3
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      Demander à FixBot
    3. Azpen A720 Battery Replacement: étape 3, image 1 de 1
      • Remove the rear casing.
      Demander à FixBot
    1. Azpen A720 Battery Replacement, Battery: étape 4, image 1 de 1
      • Locate the batteries' connection points.
      Demander à FixBot
    2. Azpen A720 Battery Replacement: étape 5, image 1 de 1
      Outil utilisé dans cette étape :
      • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
      • Use a soldering iron to melt the connections which attach the battery to the motherboard.
      • Disconnect the red and black wires from the motherboard.
      Demander à FixBot
    3. Azpen A720 Battery Replacement: étape 6, image 1 de 2 Azpen A720 Battery Replacement: étape 6, image 2 de 2
      • Peel the black sticker off the battery to disconnect the wifi antennae.
      Demander à FixBot
    4. Azpen A720 Battery Replacement: étape 7, image 1 de 3 Azpen A720 Battery Replacement: étape 7, image 2 de 3 Azpen A720 Battery Replacement: étape 7, image 3 de 3
      • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
      • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
      Demander à FixBot
    5. Azpen A720 Battery Replacement: étape 8, image 1 de 2 Azpen A720 Battery Replacement: étape 8, image 2 de 2
      • Remove the old battery and replace it with the new battery.
      Demander à FixBot
Ligne d'arrivée
Ben
Membre depuis le 03/18/15
280 Réputation
2 tutoriels rédigés
Équipe
Michigan Tech, Team 1-3, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 21
Total : 2,627
