Aller au contenu principal
Pour réparer ensemble - Je crée un compte
BLU Studio G Screen Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 8 sont issues d'un tutoriel marqué comme étant en cours.
    BLU Studio G Screen Replacement, Motherboard Prerequisite: étape 1, image 1 de 3 BLU Studio G Screen Replacement, Motherboard Prerequisite: étape 1, image 2 de 3 BLU Studio G Screen Replacement, Motherboard Prerequisite: étape 1, image 3 de 3
    • To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
    Demander à FixBot
    Ajouter un commentaire
  2. BLU Studio G Screen Replacement: étape 2, image 1 de 2 BLU Studio G Screen Replacement: étape 2, image 2 de 2
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    Demander à FixBot
  3. BLU Studio G Screen Replacement: étape 3, image 1 de 2 BLU Studio G Screen Replacement: étape 3, image 2 de 2
    • Unscrew the 13 Phillips #0 screws from the back of the phone.
    Demander à FixBot
  4. BLU Studio G Screen Replacement: étape 4, image 1 de 1
    • To remove the back panel, slide the metal spudger into 3 notches on left and right side outside edges of the device.
    • With some slow but strong pressure insert and dislodge the panel from the rest of the device. These are tough but small clips that hold together the back panel.
    Demander à FixBot
  5. BLU Studio G Screen Replacement: étape 5, image 1 de 2 BLU Studio G Screen Replacement: étape 5, image 2 de 2
    • Remove all 8 3.175 mm screws that secure the motherboard in place.
    • Remove by turning counter clockwise using a Phillips #0 bit with the correct screwdriver using medium/ firm pressure, assuring that you don't strip the screws.
    • Set aside
    Demander à FixBot
  6. BLU Studio G Screen Replacement: étape 6, image 1 de 3 BLU Studio G Screen Replacement: étape 6, image 2 de 3 BLU Studio G Screen Replacement: étape 6, image 3 de 3
    • Locate the two connector clamps on the motherboard.
    • Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
    • Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
    Demander à FixBot
  7. BLU Studio G Screen Replacement: étape 7, image 1 de 1
    • Locate the speaker on the bottom of the device and slowly pry upwards and to the right as its wired to the motherboard.
    Demander à FixBot
  8. BLU Studio G Screen Replacement: étape 8, image 1 de 3 BLU Studio G Screen Replacement: étape 8, image 2 de 3 BLU Studio G Screen Replacement: étape 8, image 3 de 3
    • Locate the volume button strip on the left side of the device and slowly pry outwards from one end to the other from the device.
    • Carefully pull over the motherboard.
    Demander à FixBot
  9. BLU Studio G Screen Replacement, Screen: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    • Turn the phone over after detaching the connectors that were attached to the motherboard
    • Carefully pry between the screen and the bevel with precision tweezers lifting slowly separating the screen.
    • Use of another thin tool will help support the lifting
    Demander à FixBot
  10. BLU Studio G Screen Replacement: étape 10, image 1 de 3 BLU Studio G Screen Replacement: étape 10, image 2 de 3 BLU Studio G Screen Replacement: étape 10, image 3 de 3
    • Insert the metal spudger between the screen and the frame, using the blue plastic tool as a brace to prevent the screen from reattaching to the frame.
    • To fully remove the screen from the frame, repeat the previous step around the entire perimeter of the device.
    • Carefully remove the screen.
    Demander à FixBot
4 autres ont terminé cette réparation.
5 commentaires de tutoriel
Thank YOU and I will begin disassembling my BLU as soon as I receive a phone screen. that is entirely different but resembles my BLU enough to use these steps to complete the mission.
Lamiah - Réponse Partager
Can anyone tell me where I can buy a screen for a blu view 3
Thank you
mrcblake50@gmail.com
Charles Blake (Mr Blake) - Réponse Partager
Most thorough and informative procedure out of the many I reviewed. Thank you.
Alan Doud - Réponse Partager
I need screen fue the sam3 ministerio blu.where to buy
Alexis urdaneta - Réponse Partager
Hi
I need digitizer where can I get one
Pls reply
Thanks
BiD N Buy - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 36
Total : 2,489
