Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Basis Peak Frame Replacement
Ce dont vous avez besoin
  1. Basis Peak Frame Replacement, Frame: étape 1, image 1 de 1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
    Demander à FixBot
    Ajouter un commentaire
  2. Basis Peak Frame Replacement: étape 2, image 1 de 2 Basis Peak Frame Replacement: étape 2, image 2 de 2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
    Demander à FixBot
  3. Basis Peak Frame Replacement: étape 3, image 1 de 1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
    Demander à FixBot
  4. Basis Peak Frame Replacement: étape 4, image 1 de 1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
    Demander à FixBot
Alexander Halliwell
Membre depuis le 03/26/17
213 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G4, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S4-G4, Julie Spring 2017
UMASSD-JULIE-S17S4G4
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 24
Total : 423
