Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Basis Peak Screen Replacement
Ce dont vous avez besoin
    1. Basis Peak Screen Replacement, Frame: étape 1, image 1 de 1
      • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
      • Maintain this orientation to follow the guide.
      Demander à FixBot
      Ajouter un commentaire
    2. Basis Peak Screen Replacement: étape 2, image 1 de 2 Basis Peak Screen Replacement: étape 2, image 2 de 2
      • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
      Demander à FixBot
    3. Basis Peak Screen Replacement: étape 3, image 1 de 1
      • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
      Demander à FixBot
    4. Basis Peak Screen Replacement: étape 4, image 1 de 1
      • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
      • The clips have small lips that you can put the spudger under to get more leverage.
      • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
      Demander à FixBot
    1. Basis Peak Screen Replacement, Screen: étape 5, image 1 de 1
      • Flip over the motherboard complex and gently remove the screen with your fingers.
      Demander à FixBot
Steph
Membre depuis le 04/06/17
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G4, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S4-G4, Julie Spring 2017
UMASSD-JULIE-S17S4G4
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 29
Total : 548
