Introduction
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Ce dont vous avez besoin
Apply a heated iOpener to the rear glass for two minutes to loosen the adhesive beneath.
Apply a suction handle to the right edge of the rear glass.
Pull on the suction handle to create a gap between the rear glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the edge to the bottom right corner.
Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the eleven 3.6 mm-long screws securing motherboard cover.
Insert the tip of an opening pick under the right bottom of the motherboard cover.
Slide the opening pick along the motherboard cover to release the plastic clips that hold it in its place.
Remove the motherboard cover.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
