Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Beats Studio3 Wireless Left Driver Assembly Replacement
Ce dont vous avez besoin
  1. Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: étape 1, image 1 de 2 Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: étape 1, image 2 de 2
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
    Demander à FixBot
    Ajouter un commentaire
  2. Beats Studio3 Wireless Left Driver Assembly Replacement: étape 2, image 1 de 3 Beats Studio3 Wireless Left Driver Assembly Replacement: étape 2, image 2 de 3 Beats Studio3 Wireless Left Driver Assembly Replacement: étape 2, image 3 de 3
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
    Demander à FixBot
  3. Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: étape 3, image 1 de 2 Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: étape 3, image 2 de 2
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
    Demander à FixBot
  4. Beats Studio3 Wireless Left Driver Assembly Replacement: étape 4, image 1 de 3 Beats Studio3 Wireless Left Driver Assembly Replacement: étape 4, image 2 de 3 Beats Studio3 Wireless Left Driver Assembly Replacement: étape 4, image 3 de 3
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
    Demander à FixBot
  5. Beats Studio3 Wireless Left Driver Assembly Replacement: étape 5, image 1 de 3 Beats Studio3 Wireless Left Driver Assembly Replacement: étape 5, image 2 de 3 Beats Studio3 Wireless Left Driver Assembly Replacement: étape 5, image 3 de 3
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
    Demander à FixBot
Nayeli watts
Membre depuis le 03/16/23
543 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 Membre de l'équipe UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G4
3 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 73
Total : 2,838
