Aller au contenu principal
BlackBerry Tour 9630 Keypad Replacement
Ce dont vous avez besoin
  1. BlackBerry Tour 9630 Keypad Replacement, Battery: étape 1, image 1 de 2 BlackBerry Tour 9630 Keypad Replacement, Battery: étape 1, image 2 de 2
    • Position the phone so that the keyboard is facing down and the back is facing up.
  2. BlackBerry Tour 9630 Keypad Replacement: étape 2, image 1 de 2 BlackBerry Tour 9630 Keypad Replacement: étape 2, image 2 de 2
    • Push the center silver button upwards to release the back cover.
    • Take the back cover off and set it to the side.
  3. BlackBerry Tour 9630 Keypad Replacement: étape 3, image 1 de 2 BlackBerry Tour 9630 Keypad Replacement: étape 3, image 2 de 2
    • Grip the battery where the light grey half circles are located and pull up.
    • Set the removed battery to the side with the back cover.
  4. BlackBerry Tour 9630 Keypad Replacement, Keypad: étape 4, image 1 de 1
    • If there is an SD card, press gently on the card and slide it up to remove.
    • If there is a SIM card, press gently on the card and slide it left to remove.
    • Use the T6 Torx screwdriver to remove the four 8.00 mm screws from the back of the phone.
  5. BlackBerry Tour 9630 Keypad Replacement: étape 5, image 1 de 2 BlackBerry Tour 9630 Keypad Replacement: étape 5, image 2 de 2
    • Use an opening tool to pry the top plastic cover off.
    • There is glue securing the top plastic cover. If you have a hard time removing the cover, use the iOpener to warm and loosen the adhesive.
  6. BlackBerry Tour 9630 Keypad Replacement: étape 6, image 1 de 1
    • Use the T6 Torx screwdriver to remove the two 8.00 mm screws from the top of the phone.
  7. BlackBerry Tour 9630 Keypad Replacement: étape 7, image 1 de 1
    • Use a spudger to release the clips connecting the front and back case.
    • Separate the front and back of the device.
  8. BlackBerry Tour 9630 Keypad Replacement: étape 8, image 1 de 2 BlackBerry Tour 9630 Keypad Replacement: étape 8, image 2 de 2
    • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • Work carefully: don't pry on or accidentally scrape any small, surface mounted components on the board.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    • Don't press down on the middle of wider connectors until they're fully seated. If misaligned, the connector or the pins underneath can bend or break, causing permanent damage.
  9. BlackBerry Tour 9630 Keypad Replacement: étape 9, image 1 de 2 BlackBerry Tour 9630 Keypad Replacement: étape 9, image 2 de 2
    • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the black and white coaxial connectors (as close to the head as possible) and lift straight up from the board.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
    • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • Don't try to force the connector into place or you may permanently damage it.
  10. BlackBerry Tour 9630 Keypad Replacement: étape 10, image 1 de 1
    • Gently push up on the keyboard from below to remove the front cover frame.
    • Once you remove the front cover, the keypad and trackball will be loose.
  11. BlackBerry Tour 9630 Keypad Replacement: étape 11, image 1 de 1
    • Remove the keypad.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Mia
Membre depuis le 01/13/15
524 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 667
