Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Bosch PS21 Trigger Replacement
Ce dont vous avez besoin
  1. Bosch PS21 Trigger Replacement, Battery: étape 1, image 1 de 1
    • Pinch the two release tabs on the sides of the battery, and slide the battery out.
    Demander à FixBot
    Ajouter un commentaire
  2. Bosch PS21 Trigger Replacement, Trigger: étape 2, image 1 de 2 Bosch PS21 Trigger Replacement, Trigger: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    $3.99
    • Locate the clip that connects the two halves of the outer casing on the rear edge of the battery shaft. *Use the angled tweezers to remove the clip.
    • Place the tweezers in the groove on the inside of the clip. Use your other hand to firmly brace the drill and pull towards your body until the clip comes loose.
    Demander à FixBot
  3. Bosch PS21 Trigger Replacement: étape 3, image 1 de 3 Bosch PS21 Trigger Replacement: étape 3, image 2 de 3 Bosch PS21 Trigger Replacement: étape 3, image 3 de 3
    • Locate the eight 5.5 mm screws located on the upwards facing side of the drill.
    • Remove each screw using the T8 Torx driver, set aside in a safe place.
    • After removing all the screws, use a small or medium metal spudger remove the casing to expose the motor and trigger.
    Demander à FixBot
  4. Bosch PS21 Trigger Replacement: étape 4, image 1 de 2 Bosch PS21 Trigger Replacement: étape 4, image 2 de 2
    • Place a finger under the metal tab seen here and lift gently up to free the trigger mechanism.
    • Carefully grab the trigger assembly and gently pull upwards without taking too much out of place.
    Demander à FixBot
  5. Bosch PS21 Trigger Replacement: étape 5, image 1 de 2 Bosch PS21 Trigger Replacement: étape 5, image 2 de 2
    • Gently disconnect the two wires connecting the motor to the trigger utilizing a pair of pliers.
    • The trigger assembly is Part #:1607233422
    Demander à FixBot
6 autres ont terminé cette réparation.
Getsemani Gonzalez
Membre depuis le 02/15/16
306 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Harley Spring 2016 Membre de l'équipe IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
4 membres
4 tutoriels rédigés
2 commentaires de tutoriel
mine has always operated flawlessly, then I was putting a few screws in the bedroom shelf and it worked fine. picked it up to change rotation and it is froze up. the trigger operates the lite and the batteries are fresh. but it will not turn, tried to turn with a wrench but its locked ? motor? gear drive or trigger? It doesn’t even seem as if its trying to turn when you pull the trigger?
roadkingrick - Réponse Partager
The most difficult step in this process is disconnecting the black wire from the defective switch. The wire enters the switch block however there is no sign of a screw or fastening one can disconnect to remove that wire! That step is ‘glossed over’. Any enlightenment from anyone would be welcome.
Tony Savage - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 89
Total : 6,396
