Introduction
Having trouble turning your speaker on? Then you probably need to replace the battery. This guide will show you how to properly replace the battery of the Bose Soundlink Flex speaker. Otherwise, the speaker's battery may be dead; it takes around 4 hours to charge to 100%.
Ce dont vous avez besoin
Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
Lift the driver out, being cautious of the wires still connected to the device.
6 autres ont terminé cette réparation.
1 commentaire de tutoriel
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
