Introduction
Use this guide to replace the control panel in your camera.
Ce dont vous avez besoin
Remove the two 2mm black screws that are located on the underside of the camera.
Remove the two 3mm silver screws from the right side of camera.
Remove the 2mm screw from the back of the camera.
Remove two 2mm screws from the bottom of the camera.
Remove two 2mm screws the left side of camera.
Outil utilisé dans cette étape :Tweezers$4.99
Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
2 autres ont terminé cette réparation.
