Ce dont vous avez besoin
Lift the lid of the Perfectea
Remove the two 12mm Phillips #2 screws located at the brim of the pot.
Firmly grip the glass pot with one hand while using the other to slip the flat end of the plastic opening tool between the glass pot and the adhesive tape holding the handle to the glass pot.
Gently pry the adhesive tape from the glass pot. Work your way around the handle until the handle is loose and not attached to the pot anymore.
The bottom panel has four wires that latch on to four tabs.
Use the metal spudger to pry up one metal tab in the latch.
Apply pressure with the metal spudger to the other tab on the latch to slide off tab.
Repeat for the remaining three tabs.
The bottom panel should now be disconnected from the rest of the kettle.
3 autres ont terminé cette réparation.
4 commentaires de tutoriel
This guide applies almost identically to the Capresso H2O kettle, which doesn't have the control board. Thanks for the guide.
Hello: My Capresso water kettle failed after four months of service. Your design and quality control are highly deficient, to say the least. I would like to spend an afternoon replacing the heating elements in the dome, but I think I will throw your product into the trash where it deserves to be. It was a nice four months, however.
Dude, you don't seem to realize that this is not the manufacturer's website. This is a third-party website
