Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Casio LK-170 Button Replacement
Ce dont vous avez besoin
    1. Casio LK-170 Button Replacement, Button: étape 1, image 1 de 2 Casio LK-170 Button Replacement, Button: étape 1, image 2 de 2
      • Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
      Demander à FixBot
      Ajouter un commentaire
    2. Casio LK-170 Button Replacement: étape 2, image 1 de 1
      • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
      • Flip the middle panel up so that the component board can be seen.
      Demander à FixBot
    3. Casio LK-170 Button Replacement: étape 3, image 1 de 3 Casio LK-170 Button Replacement: étape 3, image 2 de 3 Casio LK-170 Button Replacement: étape 3, image 3 de 3
      • In this step, you will be removing a total of 26 screws.
      • First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
      • Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
      • Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
      • After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
      Demander à FixBot
    4. Casio LK-170 Button Replacement: étape 4, image 1 de 1
      • Once all the screws have been removed, lift the panel and place it face down on the keys.
      • The panel is connected to the keyboard, so do not try to remove it.
      Demander à FixBot
    5. Casio LK-170 Button Replacement: étape 5, image 1 de 2 Casio LK-170 Button Replacement: étape 5, image 2 de 2
      • Under the panel are the buttons. Remove them by pulling from any corner with your fingers.
      • Remove all the buttons that need to be replaced.
      Demander à FixBot
Eileen Tran
Membre depuis le 01/24/17
108 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-2, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 821
