Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Casio LK-170 Display Replacement
Ce dont vous avez besoin
    1. Casio LK-170 Display Replacement, Display: étape 1, image 1 de 1
      • Using JIS-1 screwdriver, remove the seven 11mm screws located on the back of the keyboard.
      Demander à FixBot
      Ajouter un commentaire
    2. Casio LK-170 Display Replacement: étape 2, image 1 de 1
      • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
      • Flip this panel up so that the component board can be seen.
      Demander à FixBot
    3. Casio LK-170 Display Replacement: étape 3, image 1 de 3 Casio LK-170 Display Replacement: étape 3, image 2 de 3 Casio LK-170 Display Replacement: étape 3, image 3 de 3
      • We will be removing a total of 26 screws on the component board..
      • First, you must use the PH-1 bit to remove the 17 8mm screws, circled in red.
      • Second, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wire. These screws are circled in orange.
      • Third, using the JIS-1 bit, remove the three 7mm screws on the circuit board.
      • After removing the circuit board, three more screws will be revealed.
      • Using the PH-1 bit, remove the last three 8mm screws, circled in green.
      Demander à FixBot
    4. Casio LK-170 Display Replacement: étape 4, image 1 de 1
      • Once all the screws have been removed, lift the component board and place it face down on the keys.
      • The component board is connected to the keyboard, so do not try to remove it.
      Demander à FixBot
    5. Casio LK-170 Display Replacement: étape 5, image 1 de 1
      • Flip over the component board to reveal the display that is currently connected to a green panel.
      Demander à FixBot
    6. Casio LK-170 Display Replacement: étape 6, image 1 de 1
      • Remove the display by carefully picking it up with your fingers from the green panel.
      Demander à FixBot
Samantha Baker
Membre depuis le 01/24/17
443 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-2, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Hey, where do you find a replacement lcd?
Albert istvab - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 17
Total : 969
