Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Casio LK-170 Key Replacement
Ce dont vous avez besoin
  1. Casio LK-170 Key Replacement, Key: étape 1, image 1 de 3 Casio LK-170 Key Replacement, Key: étape 1, image 2 de 3 Casio LK-170 Key Replacement, Key: étape 1, image 3 de 3
    • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
    • You will begin by removing 4 screws on each side of the piano, circled in red.
    • You will then remove the four screws that are a little hidden, circled in orange.
    • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
    Demander à FixBot
    Ajouter un commentaire
  2. Casio LK-170 Key Replacement: étape 2, image 1 de 2 Casio LK-170 Key Replacement: étape 2, image 2 de 2
    • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
    • You should now see the screws holding the keys in place.
    • There are five 18mm screws per section of keys.
    • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
    Demander à FixBot
  3. Casio LK-170 Key Replacement: étape 3, image 1 de 2 Casio LK-170 Key Replacement: étape 3, image 2 de 2
    • You will be able to pick up the white keys with your hands and remove them.
    Demander à FixBot
2 autres ont terminé cette réparation.
Samantha Baker
Membre depuis le 01/24/17
443 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-2, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 membres
5 tutoriels rédigés
2 commentaires de tutoriel
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - Réponse Partager
Do you know if this exposes the circuit board(s)? I need to open my Casio LK175 to figure out why it's only working with batteries. I need to test the power adapter with a load...but the easiest way to do that would probably be measuring the voltage on the pins inside the board.
Thanks for posting this BTW. I saw so many screws on the bottom. I figured a lot of em were holding the keys. I was afraid to open it up, because I figured I'd mess it up. This is very helpful!
Heather Hodge - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 20
30 derniers jours : 41
Total : 2,955
