Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Ce dont vous avez besoin
    1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: étape 1, image 1 de 1
      • Place the meter face down, and the back panel and screws can be seen.
      Demander à FixBot
      Ajouter un commentaire
    2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: étape 2, image 1 de 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: étape 2, image 2 de 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Demander à FixBot
    3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: étape 3, image 1 de 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Demander à FixBot
    4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: étape 4, image 1 de 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: étape 4, image 2 de 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Demander à FixBot
    5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: étape 5, image 1 de 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Demander à FixBot
    1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: étape 6, image 1 de 1
      • The screen is located at the top of the device.
      Demander à FixBot
    2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: étape 7, image 1 de 1
      • Carefully remove screen from device by lifting upward.
      Demander à FixBot
Anna Kihm
Membre depuis le 10/13/14
965 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 2-4, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 membres
42 tutoriels rédigés
1 commentaire de tutoriel
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 34
Total : 3,117
