Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Connecting the Keypad
    1. Connecting the Keypad, Keypad: étape 1, image 1 de 2 Connecting the Keypad, Keypad: étape 1, image 2 de 2
      • Turn the calculator over so the blue Texas Instruments logo is facing you.
      • Slide the blue cover downwards until it is completely removed from the calculator.
      Demander à FixBot
      Ajouter un commentaire
    2. Connecting the Keypad: étape 2, image 1 de 1
      • If the keypad is not already connected, skip the next 2 steps.
      • Turn the calculator over so the keypad is facing down.
      • Locate the sliding latch towards the bottom of the calculator.
      Demander à FixBot
    3. Connecting the Keypad: étape 3, image 1 de 2 Connecting the Keypad: étape 3, image 2 de 2
      • Slide the latch to the right to release the keypad.
      • At the same time, pull the keypad downwards.
      Demander à FixBot
    4. Connecting the Keypad: étape 4, image 1 de 2 Connecting the Keypad: étape 4, image 2 de 2
      • Take note of where the keypad and the calculator connect.
      Demander à FixBot
    5. Connecting the Keypad: étape 5, image 1 de 3 Connecting the Keypad: étape 5, image 2 de 3 Connecting the Keypad: étape 5, image 3 de 3
      • Slide the keypad directly into where it connects to the calculator until you hear a click. Readjust as necessary.
      Demander à FixBot
    6. Connecting the Keypad: étape 6, image 1 de 1
      • Press the "ON" button to make sure that the calculator turns on. If the calculator turns on correctly, you have properly inserted the keypad.
      Demander à FixBot
If the keypad was inserted properly, the calculator should turn on without any errors.
Mariel Sanchez
Membre depuis le 09/27/12
22 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-52, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 membres
41 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 27
Total : 15,509
