Aller au contenu principal
Contixo V8 Headphone Jack Replacement
Ce dont vous avez besoin
  1. Contixo V8 Headphone Jack Replacement, Headphone Jack: étape 1, image 1 de 2 Contixo V8 Headphone Jack Replacement, Headphone Jack: étape 1, image 2 de 2
    • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
    • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
    • Lift the face of the tablet.
  2. Contixo V8 Headphone Jack Replacement: étape 2, image 1 de 1
    • Remove the three 1.4 mm screws from the motherboard with the Phillips size #000 screwdriver.
  3. Contixo V8 Headphone Jack Replacement: étape 3, image 1 de 3 Contixo V8 Headphone Jack Replacement: étape 3, image 2 de 3 Contixo V8 Headphone Jack Replacement: étape 3, image 3 de 3
    • The cable marked in red is locked into place by two dark pull tabs; pull each away from the cream connection port towards the edge of the tablet. Gently remove the cable once the tabs are in the open position.
    • This cable must be reattached by inserting its end into the port with a moderate amount of force (to ensure proper connection) and then sliding both dark locking tabs back into place against the cream port.
    • The cables marked in orange are known as zero-insert force cables. To remove the connection, flip up the dark tab and gently pull the ribbon away.
    • ZIF ribbon cables must be reattached by sliding the cable into place (without force, as implied by the name) and flipping the dark locking tab back into place. Please see this guide if you're having issues reattaching the ZIF cables.
  4. Contixo V8 Headphone Jack Replacement: étape 4, image 1 de 2 Contixo V8 Headphone Jack Replacement: étape 4, image 2 de 2
    • Lift the motherboard off the base and flip it over to access the headphone jack. Make sure you have the right port; check that it's shaped for headphones to be plugged in, and not the charger.
    • There will be a total of five connections between the headphone jack and the back of the motherboard; desolder all five. See this guide for information on how to desolder connections.
    • You will need to resolder the new headphone jack back to the motherboard to replace it and reassemble the device; see this guide for information on how.
    • Remove the desoldered jack. It is now ready to be replaced.
Erin
Membre depuis le 09/08/23
247 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 91
