Introduction
The following instructions will guide you through the replacement of your Contixo V9 Motherboard. You can troubleshoot the device here before starting this guide to identify its exact issue. The replacement of the Motherboard should allow the device to function like normal. This task does not require any special skills but please reference the guides found in the steps that may be viewed as difficult. Lastly, be careful as some of the parts may be fragile.
Ce dont vous avez besoin
Find the separation line between the front and back side of the device on the outer edge of the tablet.
Use the plastic opening tool to pry apart the tablet, lifting the face off.
