Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Controller Plate/Buttons Replacement
Ce dont vous avez besoin
  1. Controller Plate/Buttons Replacement, Controller Plate/Buttons Replacement: étape 1, image 1 de 1
    • Follow the Prerequisite Guide on how to Replace the Battery to prepare the phone for disassemble. Remove, but do not replace the battery.
    Demander à FixBot
    Ajouter un commentaire
  2. Controller Plate/Buttons Replacement: étape 2, image 1 de 1
    • Remove all screws on the plastic case with a T6 Torx T-4 screwdriver, as shown.
    • Blue Circle: T6 Torx, Length 5mm
    • Red Circle: T6 Torx, Length 4mm
    • The screen and other parts are now loose and can easily fall off.
    Demander à FixBot
  3. Controller Plate/Buttons Replacement: étape 3, image 1 de 1
    • Separate the back cover from the phone. A plastic removal tool can be used here.
    Demander à FixBot
  4. Controller Plate/Buttons Replacement: étape 4, image 1 de 1
    • Remove the last two screws holding the motherboard to the device.
    • Orange Circle: 00 Philips head, Length 2 mm
    Demander à FixBot
  5. Controller Plate/Buttons Replacement: étape 5, image 1 de 1
    • Gently pull up the motherboard. Some force may need to be applied.
    • Some wires on the reverse side are still attached.
    • Make sure to line up the plastic connectors highlighted by the red circles when re-assembling.
    Demander à FixBot
  6. Controller Plate/Buttons Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    • Break the break the data cable connection between the motherboard and the controller plate by gently pulling out the connecting wire with tweezers.
    • When the device is orientated as shown in the picture, apply the force parallel to the motherboard and away from the device, as depicted by the red arrows.
    Demander à FixBot
  7. Controller Plate/Buttons Replacement: étape 7, image 1 de 1
    • The entire controller plate should now be free from the phone. All the buttons can now be taken off by gently pressing them out.
    • If the touch-pad joysticks do not work, the entire plate needs to be replaced.
    Demander à FixBot
3 autres ont terminé cette réparation.
Pieter Boersma
Membre depuis le 03/25/15
455 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-3, Cichon Spring 2015 Membre de l'équipe UMass Dartmouth, Team 7-3, Cichon Spring 2015
UMASSD-CICHON-S15S7G3
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 61
Total : 1,848
