Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Creative Zen Vision W Battery Replacement
Ce dont vous avez besoin
    1. Creative Zen Vision W Battery Replacement, Battery Removal: étape 1, image 1 de 3 Creative Zen Vision W Battery Replacement, Battery Removal: étape 1, image 2 de 3 Creative Zen Vision W Battery Replacement, Battery Removal: étape 1, image 3 de 3
      • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
      Demander à FixBot
      Ajouter un commentaire
    1. Creative Zen Vision W Battery Replacement, Battery: étape 2, image 1 de 2 Creative Zen Vision W Battery Replacement, Battery: étape 2, image 2 de 2
      • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
      • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
      Demander à FixBot
    2. Creative Zen Vision W Battery Replacement: étape 3, image 1 de 3 Creative Zen Vision W Battery Replacement: étape 3, image 2 de 3 Creative Zen Vision W Battery Replacement: étape 3, image 3 de 3
      • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
      Demander à FixBot
Follow these instructions in reverse order to reassemble your device.
2 autres ont terminé cette réparation.
Tim Wilson
Membre depuis le 04/11/13
143 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-2, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 membres
72 tutoriels rédigés
3 commentaires de tutoriel
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - Réponse Partager
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - Réponse Partager
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 77
Total : 7,254
