Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Creative Zen Vision W LCD Screen Replacement
Ce dont vous avez besoin
    1. Creative Zen Vision W LCD Screen Replacement, Front Cover: étape 1, image 1 de 2 Creative Zen Vision W LCD Screen Replacement, Front Cover: étape 1, image 2 de 2
      • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Creative Zen Vision W LCD Screen Replacement: étape 2, image 1 de 3 Creative Zen Vision W LCD Screen Replacement: étape 2, image 2 de 3 Creative Zen Vision W LCD Screen Replacement: étape 2, image 3 de 3
      • Run the spudger along the cover and pry.
      • Do this gently to preserve the screen
      • The button pad may fall off when the cover is removed.
      Demander à FixBot
    1. Creative Zen Vision W LCD Screen Replacement, LCD Screen: étape 3, image 1 de 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: étape 3, image 2 de 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: étape 3, image 3 de 3
      • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
      • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
      Demander à FixBot
    2. Creative Zen Vision W LCD Screen Replacement: étape 4, image 1 de 1
      • Put the screen face down so you can see where the ribbon cables are attached.
      • Remove the red sticker that covers the ribbon cable connections.
      Demander à FixBot
    3. Creative Zen Vision W LCD Screen Replacement: étape 5, image 1 de 1
      • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
      Demander à FixBot
    4. Creative Zen Vision W LCD Screen Replacement: étape 6, image 1 de 3 Creative Zen Vision W LCD Screen Replacement: étape 6, image 2 de 3 Creative Zen Vision W LCD Screen Replacement: étape 6, image 3 de 3
      • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
      • Remove the screen from the device.
      Demander à FixBot
Tim Wilson
Membre depuis le 04/11/13
143 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-2, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 membres
72 tutoriels rédigés
1 commentaire de tutoriel
Where can I get the screen
Home Watch - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 25
Total : 1,839
