Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Creative Zen X-Fi LCD Screen Replacement
Ce dont vous avez besoin
    1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: étape 1, image 1 de 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: étape 1, image 2 de 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: étape 1, image 3 de 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Demander à FixBot
      Ajouter un commentaire
    1. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: étape 2, image 1 de 1
      • The black rubber button pad can be removed by simply picking it up.
      Demander à FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: étape 3, image 1 de 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Demander à FixBot
    2. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: étape 4, image 1 de 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Demander à FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: étape 5, image 1 de 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Demander à FixBot
    2. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: étape 6, image 1 de 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Demander à FixBot
    3. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: étape 7, image 1 de 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Demander à FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: étape 8, image 1 de 2 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: étape 8, image 2 de 2
      • Lift the right edge of the motherboard off the back case.
      • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
      Demander à FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: étape 9, image 1 de 2 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: étape 9, image 2 de 2
      • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
      Demander à FixBot
    2. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: étape 10, image 1 de 1
      • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
      • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
      Demander à FixBot
3 autres ont terminé cette réparation.
Westley Courchene
Membre depuis le 01/13/15
3 410 Réputation
14 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 13
30 derniers jours : 72
Total : 2,085
