Introduction
This guide will show you how to successfully replace an arm on the DJI Mini 2 drone, this will allow a drone with body damage to be repaired and fly again.
The drone arm stores the wires that connect the motors attached to the propellers and motors themselves. Damage to the drone arms can cause the drone have an unstable flight or ground the drone.
This guide requires the use of ESD-safe tools and a Soldering Kit. If you are new to soldering here is a guide to help you with this process.
Ce dont vous avez besoin
Face the DJI Mini 2 away from you so that you are looking at the charging ports.
Use your finger to open up the back panel.
Unfold the wings of the drone.
Place the drone upside down on a flat surface.
5 autres ont terminé cette réparation.
Un commentaire
complete and comprehensive guide, Easy to follow.
Only two small points of critique,
On step 5 It says "Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams."
This seemed almost impossible to do withcout damaging the plastic.
I then found a youtube video that showcased that you can unclip a few lips inside the drone, this made the cover come off much easyer.
The video also showed an easyer whay to put the pint removed in step 14 back in.
Apart form these two tips, the guide is practically perfect
The video is by: J T
