Aller au contenu principal
Pour réparer ensemble - Je crée un compte
DKnight MagicBox II Button Panel Replacement
Ce dont vous avez besoin
  1. DKnight MagicBox II Button Panel Replacement, Front Panel Assembly: étape 1, image 1 de 2 DKnight MagicBox II Button Panel Replacement, Front Panel Assembly: étape 1, image 2 de 2
    • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
    Demander à FixBot
    Ajouter un commentaire
  2. DKnight MagicBox II Button Panel Replacement: étape 2, image 1 de 3 DKnight MagicBox II Button Panel Replacement: étape 2, image 2 de 3 DKnight MagicBox II Button Panel Replacement: étape 2, image 3 de 3
    • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
    Demander à FixBot
  3. DKnight MagicBox II Button Panel Replacement: étape 3, image 1 de 2 DKnight MagicBox II Button Panel Replacement: étape 3, image 2 de 2
    • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
    Demander à FixBot
  4. DKnight MagicBox II Button Panel Replacement: étape 4, image 1 de 2 DKnight MagicBox II Button Panel Replacement: étape 4, image 2 de 2
    • Pull apart the two faces to separate the back panel from the front face plate.
    Demander à FixBot
  5. DKnight MagicBox II Button Panel Replacement, Motherboard: étape 5, image 1 de 2 DKnight MagicBox II Button Panel Replacement, Motherboard: étape 5, image 2 de 2
    • Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
    Demander à FixBot
  6. DKnight MagicBox II Button Panel Replacement: étape 6, image 1 de 1
    • Using your fingers gently pry the motherboard loose from the black insulant adhesive
    Demander à FixBot
  7. DKnight MagicBox II Button Panel Replacement: étape 7, image 1 de 1
    • Disconnect the Button Panel plug (Largest of the Plugs, it can be traced back to the button panel easily)
    Demander à FixBot
  8. DKnight MagicBox II Button Panel Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    • Use the tweezers to push down on the safety prongs on the plastic switch. Then Disconnect the Power Wire plug by hand (Red medium),
    Demander à FixBot
  9. DKnight MagicBox II Button Panel Replacement: étape 9, image 1 de 1
    • Use the tweezers to push down on the two safety prongs on the plastic switch. Then Disconnect the two Speaker plug connections by hand (Two Smaller Plugs)
    Demander à FixBot
  10. DKnight MagicBox II Button Panel Replacement: étape 10, image 1 de 2 DKnight MagicBox II Button Panel Replacement: étape 10, image 2 de 2
    • The Motherboard is now free from the speaker assembly
    Demander à FixBot
  11. DKnight MagicBox II Button Panel Replacement, Button Panel: étape 11, image 1 de 1
    • Remove the three screws holding the button board in place (Screw Head PH1, Size 0.5 cm)
    • You should now be able to remove the button panel from the device.
    Demander à FixBot
Anthony
Membre depuis le 02/04/16
704 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 17-1, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 17-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G1
4 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 29
Total : 1,198
