Aller au contenu principal
Pour réparer ensemble - Je crée un compte
DYMO LabelPOINT 100 Keypad Replacement
Ce dont vous avez besoin
    1. Demander à FixBot
      Ajouter un commentaire
    2. DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: étape 2, image 1 de 2 DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: étape 2, image 2 de 2
      • Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
      • Remove the blade cutter assembly.
      • Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
      Demander à FixBot
    3. DYMO LabelPOINT 100 Keypad Replacement, Remove Access Panel: étape 3, image 1 de 1
      • Gently remove the access panel from the right side of the device.
      • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
      Demander à FixBot
    4. DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: étape 4, image 1 de 2 DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: étape 4, image 2 de 2
      • Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
      • Gently lift the bottom of the circuit board, revealing the keypad.
      • Be careful not to damage any components on the circuit board when disassembling.
      Demander à FixBot
    5. DYMO LabelPOINT 100 Keypad Replacement, Remove Keypad: étape 5, image 1 de 1
      • Remove the keypad from the front facing cover
      • When installing the new keypad, make sure all buttons are correctly set in each hole so that each button can be pressed.
      Demander à FixBot
Mike Dam
Membre depuis le 09/25/14
201 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-2, Mcgee Fall 2014 Membre de l'équipe USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 membres
30 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 33
Total : 1,552
