Introduction
The power switch is the combination of two pieces working together, the mechanical switch and the electronic switch. If the switch is problematic, you may want to replace one or both of these components.
Ce dont vous avez besoin
Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
There is an inner plastic guard behind the motor shaft.
Unscrew the four screws at each corner.
The guard should pull out with a good firm tug.
3 autres ont terminé cette réparation.
1 commentaire de tutoriel
Very clear and concise guide with relevent pictures. Very well done, thank you
