Aller au contenu principal
Pour réparer ensemble - Je crée un compte
DeWalt DWD112 Field Replacement
Ce dont vous avez besoin
  1. DeWalt DWD112 Field Replacement, Power Cord: étape 1, image 1 de 1
    • Remove seven TR20 Torx Security screws from the side of the drill.
    Demander à FixBot
    Ajouter un commentaire
  2. DeWalt DWD112 Field Replacement: étape 2, image 1 de 1
    • Remove the top cover to reveal the inside of the drill.
    • Set the top cover of the drill aside.
    Demander à FixBot
  3. DeWalt DWD112 Field Replacement: étape 3, image 1 de 1
    • The power cord and the trigger act as a single part and must be replaced together.
    • Using one hand grab the trigger box and with the other grab the end of the wire connecting to the trigger box and disconnect the wire.
    Demander à FixBot
  4. DeWalt DWD112 Field Replacement: étape 4, image 1 de 1
    • Disconnect the second connected wire from the top of the trigger box.
    Demander à FixBot
  5. DeWalt DWD112 Field Replacement: étape 5, image 1 de 1
    • Lift the trigger box up to reveal the bottom side.
    • Disconnect the first connected wire from the bottom of the trigger box.
    Demander à FixBot
  6. DeWalt DWD112 Field Replacement: étape 6, image 1 de 1
    • Disconnect the last wire from the trigger box using the same method from the previous step.
    Demander à FixBot
  7. DeWalt DWD112 Field Replacement: étape 7, image 1 de 1
    • After all four wires are disconnected, the trigger and power cord are separated from the drill.
    • The power cord and trigger can be set aside if further disassembly is required.
    Demander à FixBot
  8. DeWalt DWD112 Field Replacement, Armature: étape 8, image 1 de 1
    • Take note of the keyless chuck and the meshing of the gears.
    Demander à FixBot
  9. DeWalt DWD112 Field Replacement: étape 9, image 1 de 2 DeWalt DWD112 Field Replacement: étape 9, image 2 de 2
    • Grab the metal chuck by the rotating spindle as if you are to tighten in a drill bit.
    • Lift the metal chuck out of its resting place and set aside.
    Demander à FixBot
  10. DeWalt DWD112 Field Replacement: étape 10, image 1 de 3 DeWalt DWD112 Field Replacement: étape 10, image 2 de 3 DeWalt DWD112 Field Replacement: étape 10, image 3 de 3
    • With your left hand, grab hold of the field, which is the large metal block with coils looped around the inside.
    • Use your other hand to take the bearing out from the end of the gear connected to the armature.
    Demander à FixBot
  11. DeWalt DWD112 Field Replacement: étape 11, image 1 de 3 DeWalt DWD112 Field Replacement: étape 11, image 2 de 3 DeWalt DWD112 Field Replacement: étape 11, image 3 de 3
    • Lift the field up once more with one hand and grab the cooling fan with the other hand and gently slide the armature out of the field.
    • The brushes will now be disconnected from the armature, meaning no current can flow from the power cord to the motor.
    Demander à FixBot
  12. DeWalt DWD112 Field Replacement, Field: étape 12, image 1 de 3 DeWalt DWD112 Field Replacement, Field: étape 12, image 2 de 3 DeWalt DWD112 Field Replacement, Field: étape 12, image 3 de 3
    • Move the black wire clear from any obstruction.
    • Repeat this step for the white wire and the red wire.
    Demander à FixBot
  13. DeWalt DWD112 Field Replacement: étape 13, image 1 de 2 DeWalt DWD112 Field Replacement: étape 13, image 2 de 2
    • The field is disconnected from all other parts.
    • Grab the field and gently lift it out of the case.
    Demander à FixBot
Samantha McSweeney
Membre depuis le 03/07/16
407 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Isaacson Spring 2016 Membre de l'équipe UMass Dartmouth, Team 2-3, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G3
3 membres
6 tutoriels rédigés
1 commentaire de tutoriel
as a recommendation aimed at some or mark with a piece of ribbon cables disconnected the trigger with the contact number that corresponds to the rearm the drill going to not reverse the change control rotation.
Jorge Diaz Viera - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 38
Total : 1,177
