Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Alienware 14 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Alienware 14 Memory Module Replacement, Close the Display: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
    Demander à FixBot
    Ajouter un commentaire
  2. Dell Alienware 14 Memory Module Replacement, Remove the Screws: étape 2, image 1 de 2 Dell Alienware 14 Memory Module Replacement, Remove the Screws: étape 2, image 2 de 2
    • Remove the screws that secure the base cover to the computer base.
    Demander à FixBot
  3. Dell Alienware 14 Memory Module Replacement, Slide and Lift the Base Cover: étape 3, image 1 de 1
    • Slide and lift the base cover off the computer base.
    Demander à FixBot
  4. Dell Alienware 14 Memory Module Replacement, Align the Tabs: étape 4, image 1 de 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
    Demander à FixBot
  5. Dell Alienware 14 Memory Module Replacement, Replace the Screws: étape 5, image 1 de 1
    • Replace the screws that secure the base cover to the computer base.
    Demander à FixBot
  6. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: étape 6, image 1 de 1
    • Turn the computer over and open the display.
    Demander à FixBot
  7. Dell Alienware 14 Memory Module Replacement, Disconnecting the Battery Cable: étape 7, image 1 de 1
    Demander à FixBot
  8. Dell Alienware 14 Memory Module Replacement, Remove the Screws: étape 8, image 1 de 1
    • Remove the screws that secure the battery to the computer base.
    Demander à FixBot
  9. Dell Alienware 14 Memory Module Replacement, Using the Battery Cable: étape 9, image 1 de 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
    Demander à FixBot
  10. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: étape 10, image 1 de 1
    • Turn the computer over and open the display as far as possible.
    Demander à FixBot
  11. Dell Alienware 14 Memory Module Replacement, The Power Button: étape 11, image 1 de 1
    • Press and hold the power button for five seconds to ground the system board.
    Demander à FixBot
    • Close the display and turn the computer over.
    Demander à FixBot
  12. Dell Alienware 14 Memory Module Replacement, Align the Tabs: étape 13, image 1 de 1
    • Align the tabs on the NEW battery with the slots on the computer base.
    Demander à FixBot
  13. Dell Alienware 14 Memory Module Replacement, Align the Screw Holes: étape 14, image 1 de 1
    • Align the screw holes on the battery with the screw holes on the computer base.
    Demander à FixBot
  14. Dell Alienware 14 Memory Module Replacement, Replace the Screws: étape 15, image 1 de 1
    • Replace the screws that secure the battery to the computer base.
    Demander à FixBot
  15. Dell Alienware 14 Memory Module Replacement, Connect the Battery Cable: étape 16, image 1 de 1
    • Connect the battery cable to the system-board connector.
    Demander à FixBot
  16. Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: étape 17, image 1 de 3 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: étape 17, image 2 de 3 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: étape 17, image 3 de 3
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    Demander à FixBot
  17. Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: étape 18, image 1 de 2 Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: étape 18, image 2 de 2
    • Remove the memory module from the memory-module connector.
    Demander à FixBot
  18. Dell Alienware 14 Memory Module Replacement, Align the Notch: étape 19, image 1 de 2 Dell Alienware 14 Memory Module Replacement, Align the Notch: étape 19, image 2 de 2
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
    Demander à FixBot
  19. Dell Alienware 14 Memory Module Replacement, Slide the Memory Module: étape 20, image 1 de 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Demander à FixBot
Terrence15
Membre depuis le 12/18/17
80 125 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
45 membres
2 003 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 29
Total : 558
