Aller au contenu principal
Dell Inspiron 13-7373 Daughterboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: étape 1, image 1 de 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: étape 1, image 2 de 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: étape 1, image 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Daughterboard Replacement, Network Card: étape 2, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  3. Dell Inspiron 13-7373 Daughterboard Replacement, Daughterboard: étape 3, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  4. Dell Inspiron 13-7373 Daughterboard Replacement: étape 4, image 1 de 1
    • Remove the daughterboard.
Kristen Gismondi
Membre depuis le 11/12/14
92 120 Réputation
241 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 465 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 21
Total : 351
