Aller au contenu principal
Dell Inspiron 15 5584 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5584 Wi-Fi Card Replacement, Bottom Cover: étape 1, image 1 de 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Wi-Fi Card Replacement: étape 2, image 1 de 3 Dell Inspiron 15 5584 Wi-Fi Card Replacement: étape 2, image 2 de 3 Dell Inspiron 15 5584 Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Wi-Fi Card Replacement: étape 3, image 1 de 2 Dell Inspiron 15 5584 Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Wi-Fi Card Replacement: étape 4, image 1 de 2 Dell Inspiron 15 5584 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 1 de 3 Dell Inspiron 15 5584 Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 2 de 3 Dell Inspiron 15 5584 Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 3 de 3
    • Remove the single 3 mm screw that holds down the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the motherboard.
Kristen Gismondi
Membre depuis le 11/12/14
92 069 Réputation
241 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 454 tutoriels rédigés
Un commentaire
The problem isn't taking the card out. It's putting it in and especially attaching the micro connectors to the card without messing them up. This is a poor design which literally requires a electron microscope to see what your doing. I would like ot know how one does this and with what tools.
SCWD - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 5
Total : 145
